Brief Description: Added Passenger side door gusset
Installed the passenger side door gusset. Used a #20 hole strap to locate hole and drill in gusset. Drilled 7/8" holes for the fuel and vent hose and then deburred, primed and clecoed on. Bent the hinge rod on the pilot side door hinge 90 degrees as per the plans. Got on the Zenith Forum and studied what other builders had done with the door handle and linkeages.
