Doug's Web Site
Date:  4-29-2017
Brief Description:  Pilot side door gusset
Sanded the pilot door a bit more. Fit is satisfactory. Decided to install the pilot door gusset. Drilled a 7/8" hole to match the hole in side of fuselage. The gusset is too small for both holes so ended up using a nibbler to shape a half moon for the vent hole. Drilled holes to match existing holes in fuselage and added two more for the sil. Debured, primed and clecoed in place.
Door gusset
Door gusset
Door hinge and gusset
