Brief Description: Fuel low level sensor and NACA vents
Dean dove in and helped with fitting the fuel low level sensor in the Skytek header tank. The bung hole needed a little filing to allow the threads on the sensor to seat in the tank. We eyeballed the final fit for the NACA vent and then I cut out the holes with a dremel cutoff wheel. Dean filed the openings and we confirmed the fit. Today I ordered the EXPBus II power panel, Annunciator panel, and a couple of mounts for the circuit board.
