Reinstalled the modified ADAHRS platform. I made it adjustable with brass bolts and wing nuts. Played with it a bit and saw that it indeed adjusts level on the ADI. Set it to level with digital scale. Then we ran the engine again. On the first run of about 5 min we noticed a small fuel leak around the collar of the aux pump. We have seen this same leak on the main pump before we purchased a new pump. Deano tightened the nut and that mostly corrected the issue. We did see a few drops later on shutdown. The second run was abut 15 min. All in all the engine ran great, pressures and temps normal. The RPM idle was adjusted as it is indicating too high. With throttle pulled almost full out it is indicating about 1500 RPM. Idle will need more adjustment.
