Decided to remove the ADAHRS to modify its pedestal. Have been having issues with the ADI maintaining level attitude since installing. One possible cause might be that the ADAHRS is not at absolute 0 degrees. When I built the pedestal I used an angle of 7 degrees up which should be more like 11 degrees I think. So, I've pulled the pedestal and am going to make it adjustable. That way I can adjust the position to achive the correct angle with the airframe. Next, I reinstalled the map box and affixed the RAM accessories for the Ipad.
