Brief Description: Found the Trim indicator problem
We have been having a trim and flap indicator problem. Both widgets did not indicate the movement of the trim or flaps. We started at the trim servo in the elevator thinking we might have had a bad crimp or cross wiring problem. That was not the case. So we took out the Skyview to give us access to the EMS wiring bundle. We traced the wire bundle that came from trim servo in the tail up through the console to the EMS wire bundle. Fortunately, in the console we saw the trim wire bundle and the three wires that go to the EMS bundle. We found the problem, as the three wires were not hooked up. We spliced longer wires to these and then spliced them to the signal, 5v, and ground. We then configured the trim and flaps and the widgets indicated properly except for one more issue. When we run the flaps down the trim moves wiith it. So, hopefully that will be an easy fix.
