Doug's Web Site
Date:  10-14-2018
Number of Hours:  3.00
Brief Description:  Finished riveting rubber baffle
We finished attaching the rubber baffles to both sides using a 3/4" washer and A5 rivets. The rear baffle section we riveted on the back but not on the sides. That will allow it to fold with the side baffles. Dean built a support for positive and negative electrodes that will allow us to trickle charge the battery. The support will go just behind the oil dip stick and will be accessible through the oil access door. We were going to put 5 gallons of gas in the right tank to check for leaks. Fortunately, Dean saw that we had not connected the fuel feed and fuel vent lines so we aborted the filling operation.
Baffle riveted
Baffle riveted
Scond baffle riveted
Battery charge support
