Added the pilot side rear pin angle. Drilled the holes to size 20 and clecoed. Drilled the holes in the fuselage for the striker angle and clecoed that in place. Ready to remount the door and add the piano hinge pin. Then we can see how much of the rear rod will have to be cut off.
