Brief Description: Installed seat belt, screws in arm rest tunnel
Installed the clip portion of the seat belt on the arm rest. Used a nylon washer between the bolt head and arm rest tunnel. The portion of the body belt that bolts to the anchor in the rear fuselage is a problem. Needed to insert the AN5 bolt in the opening before riveting the piece to the fuselage--not enough clearance to get the bolt through. So, tomorrow will have to drill out the rivets and get the bolt in. Finished inserting screws in the armrest top to the tunnel.
