Brief Description: Finished windshield, screws in panel
Added butyl tape to both sides of top trim strip. Then riveted strip to skylight using aluminum rivets. Used 8-32 stainless screws and 1/4" tubing pieces to attach strip to cage cross bar. The holes in the bar were tapped for the screws. Replaced the clecoes in the instrument panel with screws and plastic washers. Did same with the map box.
