Dean had a prototype bullet nose printed for the mass weight. It fits perfectly in 1 1/2" pvc pipe and will fit around each flaperon weight. Will print three more and cut a section of pvc 9mm long for each weight. I cleaned up the autopilot wires hanging out of the access opening. Put a back shell on each D9 plug and then routed the wires and riveted them to the fuselage. I reconstructed the map box because it was conflicting with the fuse trap door. I cut a chunk out and away from the fuse panel. I then used that part cut to fit and redid the box. Looks good and presents no problem to the fuse panel anymore.
