Doug's Web Site
Date:  5-21-2018
Number of Hours:  3.50
Brief Description:  Added Pilot side flaperons
Today we bolted on the two pilot side flaperons. The outboard flaperon has a trim tab powered by a Ray Allen servo. Dean drilled a small hole in the trailing edge of the wing and we fished a tape to the access panel. We sent a string back and then brought the servo wire back to the access panel. The whole operation went smoothly. I temporarily installed the two mass weights to the passenger side flaperons. I had taken more material out and they look very much like swiss cheese. Looks like the weights are now correct and the flaperons are balanced. We will construct a sleeve that will go over the weights and we can add shot if need be. Dean plans on getting some plastic noses printed for the weights.
Fishing trim tab wire
Pilot flaperons and trim tab
Passenger side flaperon weights
