Brief Description: Drilled holes in flaperon weights
Prepared the two weights for the right side flaperons. Drilled the holes on the weights that coincide with the rivet holes on the flaperons. Brought them home and started to drill three 1/2" holes on the top of the weights. I plan on expanding these holes to remove more weight if need be to achieve the neutral balance. I like this better than grinding or cutting off the bottom.
