Doug's Web Site
Date:  5-5-2018
Number of Hours:  7.00
Brief Description:  Attached the wings
Today we attached the wings to the fuselage. Basically followed the guidance of John Croke and Homebuilt Help videos. Dean and my fam pitched in and did the deed. After a lot of measuring, some cutting, lifting and bolting we got the wings up on ladders and then bolted to the fuselage. We did the appropriate measuring for incidence and sweep and then drilled the rear wing spar. We set the dihedral at 85mm and then cut the struts to fit. After bolting the struts to their fittings and to the fuselage and wing we were done.
Heaving a wing
Heaving a wing
Drilling strut
Drilling strut
Wings on
Wings on
