Doug's Web Site
Date:  5-3-2018
Number of Hours:  4.00
Brief Description:  Trimmed wing skin around forward spar
Trimmed the wing skin around the forward spar and drilled the hole to 3/8" for bolt. Trimming the skin will allow us to insert the bolt into the forward U joint. I trimmed about 1/4" off of the trailing edge of the wing. Most builders suggested that this area needs to be trimmed before hanging the wing. Dean crimped D sub pins onto the wires coming from the fuselage that mate with the wires coming from the lights, fuel senders, OAT, and on the pilot side the aileron trim. He used D9 and D15 caps.
Expanded hole to 3/8
Expanded hole to 3/8"
D9 wire connector
D9 wire connector
Dean finishes D15 connector
