Doug's Web Site
Date:  3-15-2018
Number of Hours:  4.00
Brief Description:  Powered up Skyview first time
Today we checked a few more wires and the time had come to power up the Skyview HDX. After connecting the positive wire to the battery and taking a deep breath, we switched the master switch and Skyview switch on. Pushing the Skyview button for 2 sec and voila we had a Dynon HDX screen. Overjoyed to not see smoke! We brought the sub panels on line and then started configuring the system. We only had a couple of problems. The autopilot servos were not found basically because I had not inserted the power and ground wires into the plug. No voltage was displayed on the skyview until we connected a volt wire from the EMS to the battery. It now displays. The Aux Fuel Pump light illuminates all the time but that was caused by a wire on the wrong switch post. I will correct that tomorrow and continue with configuration. Also installed the seat cushions as it will be easier to configure sitting in the aircraft.
Powering up first time!
Coming alive
Coming alive
Seat cushions installed
