Rewired master switch and added a switch guard for the on position. Installed safety tread in front of the rudder pedals. Put a larger grommet on the plate that secures the ECU wire on the firewall. Had to do some filing on the plate for the larger grommet. Zip tied the wiring and tubing that goes through the control tunnel.
