I removed the baffles and did a little more filing to improve their fit. I also drilled the 20 size holes for rivets in the front and rear. The CHT fitting nub for the baylonet hit the cylinder head, so I ground it down so the fitting would thread into the cylinder. All four CHT probes are now installed. I sited the holes for the EGT probes according to Dynon instructions. The probe should be mounted between 2-8 inches from the cylinder head in a straight section of the exhaust tube. I found that 6" was good in all 4 exhaust tubes. Tried drilling the first 1/8" hole but my bit hardly dented the stainless exhaust tube. Dropped by Home Depot and got a better drill bit. Used some number 12 Adel clamps to finish mounting the oil pressure manifold. Started the mounting of the capacitor for the battery. Need another 32 Adel clamp.
