Brief Description: Installed air oil separator, cut baffling
I mounted the air-oil separator which was not difficult. Next, I constructed the hose for the oil pressure sensor. Torqued the banjo bolt to the crank case. Went to Home Depot and bought a brass T for mounting an additional oil pressure sensor for the oil idiot light. Got the oil pressure sensor at Autozone. Traced the lines specified by UL on the baffling and then cut them. Used a power nibbler and shears to make the cuts. Filed the edges and ran them on the deburring wheel.
