Primed and painted the two coil and voltage regulator supports. Had to sand the two heater caps to fit over the butterfly flanges. I was concerned that since the butterfly valves do not seal inside the flanges that there would be heat coming in winter or summer. That is one thing we don't need in the summer is more heat. So, Dean designed the caps and had them 3D printed. They are made of a special heat resistant plastic.
