Doug's Web Site
Date:  12-22-2017
Number of Hours:  3.00
Brief Description:  Wired the start switch
Finished wiring the start switch. We had installed the cockpit wiring bundle for the ECU. Broke out the wires that connect the coils to the start switch. The start switch gets its power from the ExBus and ran the wire that will connect to the starter on the UL 350i. Also, ran the wire from the start light to the switch.
ECU wire bundle
ECU wire bundle
ACS start switch
ACS start switch
Switch installed
Switch installed
