Brief Description: Revised heater cables and Parking Brake cable
Was not happy wih the operation of the flexible cables to the heater butterfly valves. The flex cables that came with the heater kit were small and for me prone to jam. To correct I rotated the left heater valve arm 90 degrees left so the cable approached from over head. The right valve I left alone but I installed a couple of electrical terminal lug with slotted screw to hold the cable in place. I added a terminal lug to hold both wires in place. I replaced the kt supplied flex cables with two lawn mower throttle cables that were a bit larger and much smoother in operation. For the parking brake I had constructed an arm with a nut just short of the parking brake arm to hold the cable tight. All the cables now operate smoothly and properly.
