Brief Description: Installed grounding wires for fuel pumps
Installed 4 adel clamps for the fuel pumps power and grounding wires. Cut a hole for the firewall stainless penetration kit next to the additional battery. Battery cables and the fuel pump wire will utilize this hole. Also cut the 2" hole for the ECU wire bundle. It needs to be this large to get the plug through. Installed the galvanized cover and grommet for the ECU wire bundle.
