Doug's Web Site
Date:  10-25-2017
Number of Hours:  3.50
Brief Description:  Wired stick
Dean wired the pilot stick grip and finished wiring the flap switch to the relay. I worked on cutting and installing the wires to the console USB. I also aired up the tires as they looked a little low. Confirmed the locations for the heater holes and ECU wire bundle. Dean and I also studied how the throttle cables will go through the firewall. The throttle cable will need some flex because of the hinged panel movement. I had to remove a couple of nutplates on the console top because they were interferring with mounting it correctly.
Wire bundles will be tied in console
USB wires labeled
USB wires labeled
Heater hole locations
