Brief Description: Wired autopilot, trim and flaps
Dean wired the trim for both the pilot side and copilot. He wired the flaps to relays and switch. We confirmed the correct wiring for the airleron trim. I painted the battery base and then drilled four #20 holes. I riveted it to the firewall with AS5 stainless rivets. Added cork to the battery base and firewall and then drilled two holes in the battery strap. Installed nutplates for washer screws. Next, I drilled the mounting holes in the stainless frame for the fuel pumps and course pre filters.
