Drilled two holes for the Skyview update USB and screwed it in. Drilled holes for the USB on the flaperon. Glued the carpeting to the baggage floor to the rear of the access panels. Decided to use velcro to secure the carpeting over the access panels. Worked well and the carpeting looks great. Cut two 2 5/8" holes in the torque tube tunnel top to mount two stainless cup holders. The cup holders are only 2" deep which provides a couple of incles clearance to the rudder cables. Recovered the tunnel top with carbon fiber as cutting the holes messed up the vinyl. Will probably mount the cup holders with epoxy glue.
