Brief Description: Constructed template for carpet
Removed the map box and covered the last third of it with carbon vinyl fiber. This is to insulate it in case a wire comes loose and touches it. Just a precaution. Got some brown paper for a carpet template. Obtained the measurement of the baggage area and floor. Plan to glue the carpet to the baggage shelf, and floor aft of the inspection plates. In these areas I will use carpet tape to provide access to the inspection plates. Cut the template out and then fit to aircraft. Trimmed several areas and taped in place.
