Brief Description: Cut inspection hole in pilot side baggage floor
I have been thinking about getting better access and ability to change the return fuel rubber hose under the front support. I will be able to easily change all of the other hoses, when that day comes, except for the return hose. The big access cover is right over the gascolator but I need an opening closer to the Skytek. So I cut one with the cutoff wheel and will fashion a cover and use nutplates.
