Finished wiring the flap servo by running the cable and attaching a female D9 and then mating with male D9 on the servo. Riveted the servo in place with A4 rivets. Riveted the roll servo mount with A4 and A5 rivets. Riveted the passenger side rear support with A5 rivets. Put flexible grommet material on the avionics shelf L angles as wires will drape over these. Also put some flexible grommets around the lighting holes where wires will route under the seats.
