Brief Description: Bolted autopilot pitch servo to torque tube suppor
Pulled the floor from the pilot side to add some flexible grommets around the fuel feed and return line. Drilled holes through the torque tube support for the pitch servo. Bolted it on with AN3-5a bolts and two spacers to correct the angle with the floor. Very difficult to get the nuts on and it took quite a while. Crimped the wires with D sub pins and interted them into a male D9.
