Brief Description: Clecoed pilot side baggage floor
I drilled the holes in the angle gussets into the Z channel on the lower access port. Expanded the holes to size 20. Then I added the baggage floor and clamped the fuel and return hoses to the Skytek tank. I clecoed the floor to the dropdown piece and the fuselage. I grabbed the mount for the autopilot roll servo and tested its fit on the backside of the dropdown. It looks like it will fit nicely but I will have to shorten the servo arm. Its rod end will attach to the end of the torque tube.
