Did various task today. Drilled a hole and ran the phone line type cable from the ELT to its control on the panel. Tapped the servo rod to accept the rod end at the servo arm. Will wait to do the other end when I am sure as to the exact position of the roll servo mount on the baggage floor. I temporarily screwed the Skytek tank back on the rear channel and took some measurements. Need to put some nut plates on the tank closeout that will get installed later. Fabricated the rod for the flap servo.
