DOUG'S WEB SITE
RV-7
Sec 7-6
Assembling the Right Fuel Tank
Used a fly cutter in the drill press to cut the access cover hole in the T-703 inboard root rib. Also, using the T-408 cover plate as a template, drilled holes in the inboard root rib. Installed the T-407 reinforcement ring.
RV-7 Home
1246
182
Systems
419
