Brief Description: Prepared rudder trailing edge and started the righ
Used tank sealant to set the AEX wedge into the trailing edge of the rudder and clecoed this to a piece of aluminum angle and set aside for later riveting.
Rolled the leading edge of the rudder and pop riveted
Began working on the right elevator. Fabricated all stiffeners and match drilled and dimpled and deburred everything on the elevator.
