cont. Accessory installation. Positioned heater inlet, cut 1 1/2" hole and temp installed. Temp installed starter solenoid. Also drilled holes for throttle, mixture, battery cables, and electrical bundle. Holes are marked in blue tape on photo's.
Took time out to launch my boat with Bill Reynolds.
Measured run for battery positive = 9 feet. neg about 8 feet.
NOTE DUE TO CHANGE IN PLANES - LATER MOVED HEAT INLET TO RT SIDE TO ALLOW MOUNTING OF OIL FILTER
