DARRYL'S WEB SITE
Date:  3-30-2012
Number of Hours:  1.00
Brief Description:  Engine 1st Start
Moved plane outside and connected a fuel line to a jerry can. Tested electric fuel pump, pressure seemed to read correct on the voyager, 4.5 psi. Engine fired up first touch of the starter and ran smoothly. All temps and pressures worked first time on the voyager except for RPM, which turned out to be a wire I left off. All working as it should.
