Derricks SeaRey Build
Searey
Flight Control Syste
12-30-2015
Aileron Torque Tube
Installed the Aileron Torque Tube.
Added an additional 1/8" shim to the lower bearing block. Utilized longer (AN4-32A) bolts.
I fabricated the extra shim from existing metal stock, using the existing shim as a guide.
Started to assemble the lower bellcrank tie-rod
Searey Home
513
Airframe Accessories
Baggage Area
Boom Tube
Cabin Heater
Cooling System
Electrical System
Engine Monitoring
Hull
Instrument Panel
Kit Options
Parts Delivery
Parts Inventory
Pylon
Seats
TurtledDeck
Windscreen
