Derricks SeaRey Build
Date:  10-1-2015
Number of Hours:  0.75
Manual Reference:  2.6 & 7.3
Brief Description:  Throttle & Elevator Push Tube
Section 2.6/4 Throttle Brake Assembly: Continued with this install until I realized I was missing a bolt: AN3-15
Another parts hold.
Section 7.3/Pg 2: Elevator Push Tube:
Started the fabrication/prep of the Main Push Tube. Await final assembly just prior to setting the fuselage into the hull
