Derricks SeaRey Build
Date:  9-22-2015
Number of Hours:  2.25
Manual Reference:  Various
Brief Description:  Catching up with Assembly Manual Discrepancies
No photos for today.
Spent the afternoon verifying and re-assembly to catch up with the LSA Assembly manual.
Section 1.4: Installed the Rudder Cable Standoffs
Section 2.4, 3.1, 3.2: Checked and replaced where required, all of the upper Bulhead Bolts & hardware. Especially the through boltds that will eventually afix the frame to the hull.
Section 2.5: Removed my previously installed MLG Actuators, so I could reset the Internal Limit Switches. At the same time, I made notes where I will need to replace standard un-drilled bolts with drilled versions. Some are specified in the LSA manual, others are not.
Section 7.1: Checked and updated the hardware callout for the Forward Bellcrank. Seems there was a discrepancy with the number of washers.
From this point forward, my primary reference sections will be to the LSA Manual.
