Brief Description: Rivet front spar and ribs to skin
I riveted the front spar and ribs together and clecoed it into the skin. I then riveted the assembly to the skin, followed by the rear spar. The VS is done! This is childs play compared to the HS, now I see why some recommend that it be the first assembly you do. (although I managed to screw it up) Now on to the elevators.
