Brief Description: Completed rivettinng of Horizontal Stab
More rivetting to attach the skins to the skeleton; this time I was using a pneumatic squeezer to attach the skins to the outer and inner skins. Once you've set it up for the cirrect squeeze depth it's a breeze.
Apart from permanently fitting the aft spar, the horizontal stabiliser metalwork is now essentially finished. The spar will be attached once my LAA inspector is satisfied with the quality of the workmanship, and to do that he will need to be able to view the internal structure.
