Dave White RV-7 Build Site
Date:  11-14-2009
Brief Description:  HS Forward spar bend relief (LH)
With the arrival of my new step drills this morning, I quickly opened out the #30 holes I had previously drilled into the LH front HS spar to their final size of 1/4".
Then, using a nibbler - great tool, doesn't bend the metal like aviation snips - I removed the part of the flange called for in the plans.
Hopefully I'll soon lose the sense of paranoia and approaching menace every time I cut into a part...
Bend relief and cut-back flange.  Needs tidying up.
New step drills - tape marks required 1/4
New step drills - tape marks required 1/4" step
