Dave White RV-7 Build Site
Date:  11-7-2009
Number of Hours:  4.00
Manual Reference:  HS Rear/Front Spar
Brief Description:  Completed drilling / deburring rear spar
Drilled/Match drilled rear spar including hinges and centre bearing. All rear spar tasks complete except final deburring and priming, then rivet assembly.
Began front spar; match drilled reinforcing bars and shaped upper reinforcing bar using vixen file, scotchbrite wheel and pad.
HS rear spar assembly
