Dave White RV-7 Build Site
Date:  12-23-2011
Number of Hours:  2.50
Brief Description:  Left Elevator - stiffeners
Repeat of stiffeners as produced for the right elevator, with shorter parts around elevator trim tab area and modified lengths c.f. equivalent on other control surface. That is, the outboard stiffeners on the left elevator are slightly shorter than on the other side. so parts are modified accordingly by griding to a slightly shorter length.
These stiffeners are now to be put aside until the construction commences of the slightly more complicated left elevator.
Left elevator stiffeners, with right ones behind
