Install firewall to fuse Install aft engine mount on fuse Hang engine Install balance tube with manifold pressure sensor Install exhaust system and EGT senders Fab and install oil lines and oil system Fab and install radiator hoses and radiator system Install carb heat valves and hoses Install cabin heat hoses Fab and install throttle, carb heat, choke, and cabin heat cables Fab fuel lines and install fuel system firewall fwd Various engine install tasks
