Finally got the $&^%&)^$^^%$ Bubble installed. The ratchet straps in the picture were the final key. Thanks Rick. I am going to leave them on for a while under the heat hopefully to relieve some stress.
That is my buddy Steve Dunne in the picture. Steve is the Cessna Single Dealer in Wichita.
Steps
1. Set in place 2. Attach the clip center rear 3. Attach remainder of rear clips alternating sides 4. Install passenger side door rail clips 5. Install rightmost bubble clip 6. Install remainder of bubble clips 7. You will now have a bit of slack in the bubble that will not allow you to install the remaining front clips nor the door frame clips. 8. Do not force the door frame clips or they will damage the lip 9. Install ratchet straps as shown this will squeeze the bubble into shape and allow for intallation of the remaining clips.
