Brief Description: Part #s for Control Rod Bearings
Finally got around to looking up the Part #s for the bearings and races I used on the swash plate control rods.
Bearings - IDC Select R4A 2RS These are 1/4" ID 3/4" OD 1/4" sealed ball bearings. Not a lot of science went in to this selection. I used them primarily because they fit the application from a physical stand point, and were available locally. Any high quality bearing of this type should be fine
Thrust Bearing Race - Torrington TRA 411 These are hardened bearing races that I don't have the dimensions for handy. These keep all movement against steel surfaces instead of the aluminum of the factory setup.
