Bills Safari Adventure
Date:  6-17-2012
Number of Hours:  0.00
Brief Description:  Test Flights
Since these are not building issues I am entering 0 in the time slot
I have been battling several avionics issues
1 Rotor RPM - After much anguish found that the tach sender was dead. Install a good used one and got rpm - Now unfotunately it works up to 50% rpm but goes crazy after that
2. Fuel tans not reading correctly - still working on that
3. Governor not working - Figuered out that I had not assigned a circuit to it on the VPX - now it appears to be fighting me so I need to reverse the polarity
4. Engine RPM - needed a jumper removed
5. Altenator - found out I was missing a jumper
6.Fuel Flow - needed a pullup resistor
