I Have been working but my computer has been down so no entries. These next few entries are not dated or grouped exactly like I did them, but here they are.
Photo 2 shows the underside of the ducting from the oil cooler to the flapper valve for the cabin heat. The hole was originally cut for the factory exhaust. I am using the Power Flow and the hole needed to be moved. You can see the half moon shaped filler piece that shows how much the hole had to be moved. Photo 1 shows the final product
Photo 3 shows the finalized firewall penetrations. I used 6 DoubleT eyeball penetrations. Most had to be drilled out to accomidate the multiple wires. It is a neat setup.
