It takes longer to write this entry than it took to time the mags. Fortunately I had marked the starter gear clearly where TDC was. Spin the engine by hand until the TDC spot on the gear lines up with the hole in the starter. I stuck a drill bit in the hole to make it more obvious.
Turn on the Avionics and Master but not the Mag Switch. A RED LED glows. Blow into the tube and it flashes RED. Blow again and it flashes GREEN. Turn power off and on and make sure that it is still GREEN.
That is it.
I am waiting for some answers to questions from MGL.
